AutoCAD LT Forum
Lost Multi-Select?
1 REPLY 1
FLHX
8050 Views, 1 Reply
Lost Multi-Select?
I must have done somehting or changed a setting....
I used to be able to select multiple objects to move, copy, delete, etc. just by clicking on them.  I could click on as many objects as I wanted.
Now, seemingly out of nowhere, I can only select one object, unless I hold down the shift key.  When I click on a second object, the first object "UN-selects".  Now, to select multiple objects, I have to hold down the shift key.  I know I didn't have to do that before.
Is there a box I checked or unchecked, or is there a setting I switched without realizing it?
1 REPLY 1
Charles_Shade
in reply to: FLHX
PICKADD Variable
You set it to 0 at some point.
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
”Boost
