Is there a way to apply the layer fading to locked layers when objects are within a block. Using block edit or refedit does apply the fade, but when working in normal space they appear unfaded.
I dont want the object to acctually be locked, it is effectively locked anyway as its on the layer thats is locked, that is fine. I simply want that layer to fade as it would do as if it was out of the block.
