AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Lock Attribute Position in LT2005
5 REPLIES 5
LRB45
274 Views, 5 Replies
Is it possible to lock the attribute position within a block on Autocad LT2005. Everything i find seems to be for 2008 or later so i'm thinking not.
5 REPLIES 5
Kate_LT
in reply to: LRB45
Nope, that's a dynamic block thing. 2007 & up for LT, 2006 & up for AutoCAD.
Kate Morrical
Technical Marketing Manager
Autodesk, Inc.
LT Unlimited
LRB45
in reply to: Kate_LT
Yeah I was afraid of that.  Thanks for the info.
Charles_Shade
in reply to: LRB45
Why would you need to Lock the Attribute if it is not a DynBlk?
And if it is a DynBlk you need tweaked just post it and someone will do so for you.
Dynamic Block Forum:
http://forums.autodesk.com/t5/Dynamic-Blocks/bd-p/154
pendean
in reply to: Charles_Shade
No DynBlocks in LT2005, what the OP is using.
Charles_Shade
in reply to: pendean
Thought he might have found one somewhere and it needed tweaking.
I know you cannot create but you can't use them at all in LT 2005?
”Boost
