Can anyone help loading an existing batch file to AutoCAD2013 Lt......
I have a toolbar that was setup before and I have a new machine, new cad etc and want to get everything back to the way it was.
Can anyone help.
What is the previous version of Autocad you used.
From 2008 on in the start menu there is a command "Migrate Customs Settings" you can use that.
Also I think you'll find in the same subsection of the main menus there is a command "Migrate from previous release"
Howard Walker
Or.... to avoid migrating "junk" that will mess up your LT2013 setup, explore using CUI command's TRANFER tab to transfer the toolbar and it's content from the old menu file to your current menu file.
Whether you use my tip or the other tip, both require you actually having the older LT version still available (and strill intact/operational and ideally on the same PC for the other tip).
Post back if you get stuck with either tip.
