Hi -
I have one drawing, with one xref, and two sheets.
One sheet is printing out hidden lines on the xref demo layer, the other sheet just prints them out as continuous.
mview lock is off for both sheets
both sheets are the same scale - 1/8"
ltscale is 1
psltscale is 0
I've changed the linetype for the demo layer to hidden in the xref, and within the drawing. (xref|a-demo)
Any suggestions?
Thanks!!
Solved by sthompson1021. Go to Solution.
You said that psltscale is set to 0, did you verify that on both layouts? That variable is layout specific.
