AutoCAD LT Forum
Layer Properties Manager not showing
5 REPLIES 5
553 Views, 5 Replies
AutoCAD LT 2007 - Cannot view Later Properties Manager when requested.  Any help grealty appreciated.
5 REPLIES 5
Charles_Shade
New problem?
Change from two to one Monitor?
Run a Regisry Cleaner?
in reply to: Charles_Shade
Switched to two monitors and problem is occuring again.
pendean
Windows' basic function to retreive lost command/program windows will probably work for you:
•start layermanager
•press <ALT> <SPACE>
•you'll get a popup-menu,
•use your cursor key <DOWN> to go down in the menu to "Move", then press <ENTER>
•you are now in move-mode for the dialog window
•use your cursor keys (on your keyboard!) to move the dialog to the center of the screen
•at the moment you see the layermanager you can start moving your mouse to position the dialog, then click left mouse button
in reply to: pendean
No luck.  I get the pop-up with "move" but it is not available to click on.  Reinstalled AutoCAD Friday after Microsoft dowload reaked havoc on my computer last week.
Thanks for the previous suggestion
Charles_Shade
LAYER from the Command Line.
You do not want to click on the Dialog; press M to get the Move function.
This all needs to be done with the keyboard till the dialog is Visible.
”Boost
