There is some bug in LT2014 where the drawings are occasionally (but not predictably) being saved in 2013 format, even though the saveas settings are set to 2010.
I've had it happen a few times, and a colleague has also had it happen to files she has saved.
Can we have a fix please from the developers, Most of my office is still on 2010 and I'm getting tired of being blamed by my colleagues for a problem I have not created, and also tired of getting emails from the partners where I work making it sound like either I'm doing it deliberately or I'm an idiot.
Is Save As under the Open and Save tab in Options where you have this set?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Charles,
Yes it is correct and has been since I started using it.
See screen capture below.
Charles.
Thought that is what you meant but wanted to be sure.
Next time someone tries to tar and feather you open the file in question in Notepad and see if the first group of characters is AC1024.
If so this file is on the 2010 Format. If it has AC1027 then it is 2014.
AC1027 AutoCAD 2013/2014
AC1024 AutoCAD 2010/2011/2012
AC1021 AutoCAD 2007/2008/2009
AC1018 AutoCAD 2004/2005/2006
AC1015 AutoCAD 2000/2000i/2002
AC1014 AutoCAD Release 14
AC1012 AutoCAD Release 13
I save here in 2010 Format and a random sampling of Files showed AC1024.
Charles,
I had a VB programe that read that a few years ago (when the office I worked for was dealing with a problem like this), it would read the first few letters out and then write a code against the file tag information, so you could see it in Windows Explorer.
Very useful, but a bit over the top for this problem...
Charles.
Dean, it has been none of those things, just ordinary working in files, but thanks for the suggestions.
Unfortunately one of the partners here is the kind where if you contradict them then you must be lying, they cannot be wrong....my mere 18+ years of using Autocad is nothing compared to the doctrine of management infallibility.
Maybe I need one of those shields they have on Star Trek, the kind Mr Sulu could put up to defend against things like the floating head of Zsa Zsa Gabor?
