Has anyone else had an issue with LT2014 where the use of revision clouds (regardless of what drawing used on) causes AutoCD LT2014 to crash? If so, does anyone have any solutions / tips?
Thanks in advance,
K.
(Win 7, 64-bit LT installation.)
Hello from France
Welcome to the Autodesk/AutoCAD Forums !
1) Have you the problem in a blank DWG ?
2) If you have the problem only with specific DWGs, please could you open them in RECOVER Mode and test again !
3) Have you installed the SP 1 on your ACAD LT 2014 ?
Bye, Pat
Patrice BRAUD
