AutoCAD LT Forum
LT2013 - toolbar macros not working
4 REPLIES 4
david
802 Views, 4 Replies
Toolbar macros I've been using for several versions now are not working in LT 2013, any thoughts on cause and fix?
Here an example of one of the macros:
^C^C_select;_auto;\_copy;_p;;@;@;_move;_p;;\\_rotate;_p;;@;\_redraw:
4 REPLIES 4
in reply to: david
Hello, I'm not much of a buff on macros but I looked up the help menu and if you change you PICKADD to 1  I think it might sort your problem
Regards Lawson
AutoCAD LT2010
AutoCAD LT2013
Windows7 64bit
If any answer solves your problem, remember to mark it as solved
Charles_Shade
Interesting solution. Hopefully the OP will repsond and let us know if that was it.
In the future a bit more info on when or where the Macro is failing will be helpful.
Variables between Platforms can seem to cause troubles when upgrading.
We all are "used" to something working a particular way and fully believe that that program is at fault when
it is simply a Variable that we have overlooked.
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
david
in reply to: david
That worked, thanks you very much for your feedback on the issue!  Not a variable I knew about or had knowingly adjusted.
Oh and these macros were not working at all, so total failure until setting pickadd to 1, I'll have to read more about pickadd.
Again thanks!
in reply to: david
Glad it work for you! There are a lot of strange settings on ACAD, to know how each one affected each command you'd be doing very well
Regards Lawson
”Boost
