AutoCAD LT Forum
LT2013 slow saving
4 REPLIES 4
bob_mpc
584 Views, 4 Replies
LT2013 slow saving
I have very weird problem:
Since Friday (07.03) all three systems with LT2013 (WIN7PRO, 64) are extremely slow when saving a file - either the automatic *.sv$ or normal QSAVE or SAVEAS.All was working normally till then.
It happens both at network drive and on local drive. Whenever one tries to make a save (CNTR-S) after several minutes of working, the LT freezes for 10-30 seconds. The status bar at the bottom freezes for the same time at about 50% (different every time). I tried saving a file (412K) on the desktop and for the period of freeze I see a file "savBLABLA.tmp", which later disappears when the program thaws again.
The LT is patched with SP2.
At 7th March there is DEFINITION UPDATE - WINDOWS DEFENDER.
At 5th March there is SECURITY UPDATE - MICROSOFT XML CORE SERVICES 4.0 SP2
REPAIR of LT didn't help.
I have thought of loading and installing the Trial of LT2014 - to check how will it work.
If anybody has any other ideas what to check before clean reisntallation of LT2013 - I will be very gratefull.
Boris
AutoCad LT 2021.1.1
4 REPLIES 4
JoAnn_Hogan
in reply to: bob_mpc
Ok lets first try Resetting AutoCAD.
Go to Start > All Programs > Autodesk > AutoCAD LT (Version) > Reset settings to Default
If that does not work. Clear out your temp file.
Run > %temp% > Delete all files in this folder.
If this post solved your issue please mark as solved and Kudos are always welcome 😃
Jo - Ann
Twitter: @JoAnn_Hogan
Revit Architecture Certified Professional / Revit Structure Certified Professional / AutoCAD Certified Professional
bob_mpc
in reply to: JoAnn_Hogan
Thanks a lot, will give it a try and report back
Boris
AutoCad LT 2021.1.1
bob_mpc
Thank you very much,
Till now the issue looks resolved.
Sorry for late answer, but I had quite big workload for last week.
Boris
AutoCad LT 2021.1.1
JoAnn_Hogan
I am glad it is sorted out now. Good luck with that work load
Jo - Ann
”Boost
