AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
LT2013 mac
1 REPLY 1
237 Views, 1 Reply
LT2013 mac
Recently migrated from windows to mac os and only using this version on a macbook for now until I feel confident to changeover the studio workstation after many years and trying to find some familiar ways around as I have been used to working on LT2004 (although I have upgraded many times I just never really got on with the newer pallettes etc and revert to the tried and tested version to keep productivity at work)
Can someone please help me with a couple of minor things please.... they have a major impact on my use of the product?
- Is it possible to config the content pallette so I can rotate blocks at the time of insertion without having to either post rotate them individually from the model space or use the insert command which appears not to be as graphically friendly as the content pallette which looks excellent for compiling good for libraries but the option to at least rotate will be greatly appreciated.
- Is there a quick and easy to changing linetypes on the fly from a flyout menu on the toolsets... is there any other way round this without having to access the pull down from the properties inspector pallette as that method consumes quite a bit of screen space?
I'm liking and getting used to the new feel of the software but a little concerned it may take longer to carry out repetitive tasks that I do many times each day which may stop me using this regularly so any constructive comments are most welcome, thanks
Mark
Architect in UK
1 REPLY 1
Charles_Shade
And you will need to ask in the Mac Forum I should think.
Mac Forum:
http://forums.autodesk.com/t5/AutoCAD-for-Mac/bd-p/520
To the points (Assuming same in Mac version):
1. Right click the Block in the Palette and choose Properties. Set the Prompt for Rotation to Yes.
2. Quick Properties for me is the easiest way to do this. (I'll get flamed; but I leave it running and popping up all the time.)
”Boost
