AutoCAD LT Forum
LT Windows question
3 REPLIES 3
203 Views, 3 Replies
LT Windows question
I have a question regarding LT and Windows, is there any version where a super user can operate it?
Currently I am working with 06 LT and it works as long as it is an administrator logged in but loses functionality for my power users.
Is there any version of LT that supports power users, helps me when/if I decide to upgrade
3 REPLIES 3
bgingerich
Same question asked a couple weeks ago.
http://forums.autodesk.com/t5/AutoCAD-LT/AutoCAD-LT-2007-won-t-run-on-Windows-7-as-a-power-user/td-p...
HTH
Brandon Gingerich
in reply to: bgingerich
I read the whole thread but an answer was never given if there was a version that actually enabled power users to be able to run the .exe and have it work.
thanks for trying though
Charles_Shade
There was an answer given albeit crpytic:
Power Users should not have a problem on a version of CAD that supports the current OS.
If you are using Win 7 then 2010 or newer versions.
Download the Trial of your software from Autodesk and try it out.
You may end up answering your own question.
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
”Boost
