I have been having an issue plotting DWG to PDF using AutoCAD LT 2008. Only some of my lines will show up continuous instead of as hidden after being plotted. They all show as hidden both in model space and paper space. I would be less confused if it was all lines showing as continuous but only a few objects will show up as continuous lines. Please help, I'm on a deadline here!
Solved by pendean. Go to Solution.
Hello
Welcome to the Autodesk/AutoCAD Forums !
Which PDF driver are you using ?
- Autodesk driver "DWG to PDF.pc3" ?
- PDF Creator ?
- Cute PDF ?
- Adobe Acrobat ?
- etc ?
Have you the same problem when printing/plotting to paper (same paper size) ?
Bye, Pat
Patrice BRAUD
It could also be the scale you are plotting to. Would you please attach your drawing here so we could have a look at it?
I have attached the file I am trying to plot out of. I have been using DWG to PDF.pc3 to plot.
I am using a 1/4" = 1' - 0" scale from ms to ps. I have set ltscale, msltscale, and psltscale to 1 as per another issue that was happening before.
Is this any different than what you are getting?
It is a little different, but only because I have to make everything that is yellow in this drawing (DEMO Layer now) a Hidden line. Not sure why most of them will stay as Hidden lines on my PDF after plotting. Only items I have had issues with are the sinks and toilets not showing as hidden lines after plotting but they show as hidden lines in my model and paper spaces.
Is these Toilets and sinks blocks? Drawn on the 0-Layer?
I just plotted this after changing my LTSCALE to 5 from 1. Still having the issue of not having hidden lines appear as they should. Any more possible solutions?
Unfortunately your drawing is in a little bit of a mess, you have LWEIGHT settings turned on and varying between object types and many of your objects have custom object linetype scales defined among a few other things. You're also not using PSLTSCALE and MSLTSCALE variables correctly I suspect in your layout, but nothing in your samples is initialized so I can't tell.
For a quick fix, set LTSCALE to 8 or 16 and your dashed lines will plot as dashed lines. See PDF1-model.
See PDF2-layout for my taking a stab at a it.
See the DWG file I used to create the two plots above.
LTSCALE, MSLTSCALE, CELTSCALE, and PSLTSCALE all come into play in AutoCAD.
You also need to fix the LWEIGHT settings for all your objects, and the individual linetype scales of each object. Screenshots below to show you how.
Just plotted this, still having the same issue. Even tried making the WC's and Lav's squared out instead of rounded with a lot of detail before. LTSCALE set to 8. PSLTSCALE MSLTSCALE and CELTSCALE are all set to 1.
I no longer have the problem blocks as blocks. I redrew them as simple blocks and am still having the same issue. I think, for the sake of trying to be expedient, I will just have to use a marker for them.
Thank you for all of your help. I will have to see if I can fix it later as my deadline is tomorrow afternoon at the latest.
