Does any one know if you can insert a jpeg image into an autocad lt drawing, if so could you explain.
Russ
Yes you can and many many many threads on the subject for explanation:
It has gotten easier and better over the years.
The differences may depend on your AutoCAD version.
Read up and re-post if you get stuck.
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
your LT version is...? Older versions were not able to do so easily, newer ones can use the REFERENCE palette (it's not just for DWG files, explore it in HELP).
