I am a newer user to AutoCad LT, I was wondering what the best way to import an access DataBase to a drawing file which will enable me to link Data to blocks on the map. I have done this with Map 3D in the past but could not figure out the best way to do this with LT.
I see you can add an Excel Table but can you link the info from an excel sheet the same way you would an access data table? I would prefer to use the access table if possible. Any help would be appreciated.
Thank in Advance.
LT is not MAP3D: the +$3000 discount has to come from somewhere... .
What LT version are you using? If you have something relatively current you can start reading all about it in your HELP file, or here: http://exchange.autodesk.com/autocadlt/enu/online-help/ACDLT/2012/ENU/pages/WS73099cc142f4875556e087...
