Hi all,
I am trying to plot points at a set distance from the start of a curved 2D polyline. I do know one way which is a bit long winded, which is to use the MEASURE command. However i end up with several points along the line, where as i only need the first point, so have to delete all the other points afterwards. Is there is a more straightforward way to do this?
Thanks in advance,
Jonny
How about drawing a line from the curve your certain distance and placing your point at the end of the line. Delete the line afterwards
Alternatively you can add the drawing and I can test what you want to do or add a screen shot.
Welcome to the Forums
Does it have to follow the curve of the polyline?
Do you know the length of the polyline?
I ask because you can do it with the following command
LENGTHEN.
Choose T for Total Length. Now type in the length you want.
Select your polyline
Draw your line starting at the endpoint of the polyline
LENGTHEN.
Choose T for Total Length. Now type in the length your original polyline was.
Select your polyline.
Howard Walker
Hi Jo,
If you mean a straight line, then this will be shorter than measurement along the curve, so may not be accurate enough. I have sort of solved the problem for the job i am doing by using a chainage (green line) with more divisions allowing me to plot things where i want them with reasonble accuracy. However if you have the answer to my initial question, it could be handy to know. Thanks!
