Hi all,
I am trying to plot points at a set distance from the start of a curved 2D polyline. I do know one way which is a bit long winded, which is to use the MEASURE command. However i end up with several points along the line, where as i only need the first point, so have to delete all the other points afterwards. Is there is a more straightforward way to do this?
Thanks in advance,
Jonny
How about drawing a line from the curve your certain distance and placing your point at the end of the line. Delete the line afterwards
Alternatively you can add the drawing and I can test what you want to do or add a screen shot.
Welcome to the Forums
Does it have to follow the curve of the polyline?
Do you know the length of the polyline?
I ask because you can do it with the following command
LENGTHEN.
Choose T for Total Length. Now type in the length you want.
Select your polyline
Draw your line starting at the endpoint of the polyline
LENGTHEN.
Choose T for Total Length. Now type in the length your original polyline was.
Select your polyline.
Howard Walker
Hi Jo,
If you mean a straight line, then this will be shorter than measurement along the curve, so may not be accurate enough. I have sort of solved the problem for the job i am doing by using a chainage (green line) with more divisions allowing me to plot things where i want them with reasonble accuracy. However if you have the answer to my initial question, it could be handy to know. Thanks!
Thanks mate,
Yes needs to follow curve and know the length. Looks like that will do the job, cheers!
