after purge the dwg just less 1MD only... but my orginal dwg (before install the dwg just 900KB only)..
What was the size of the image you inserted?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Something to do.
Interesting that none of the above works for the late poster.
then, it not use copy & paste the images ...can teach me how to insert images to Autocad LT 2008? give me 'command:' 'urgent...
Typically if you Open the file to be inserted in your favortie image viewer and Copy it from there it will Paste into AutoCAD.
Or the above advice does not give you what you need?
INSERTOBJ command in LT2008: read about it in HELP in LT2008, and follow the instructions exactly or it will not work.
