AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Help ! Revdate Error getting on my nerves
1 REPLY 1
152 Views, 1 Reply
Ok. AutoCAD LT 2002. Revdate command produces a block that updates
filename and time. It has benn malfunctioning, giving me the following:
Command: _revdate
Error: bad argument type: stringp nil
It did work for awhile but now it is malfunctioning again., what would
cause this.
Thank you in advance.
Sacha T. Porter
1 REPLY 1
Check the block name that is being created, and see if by any chance you
have a similar block or external file with the same name found in the
AutoCAD program's search path (OPTIONS>Files tab will show you which folders
LT searches). Remove it, then try the command again.
Dean Saadallah
http://www.pendean.com
Expanded Links Page
http://www.pendean.com/lt/links.htm
"Sacha T. Porter" wrote in message
news:3DB6A38D.5AFE3760@blazenet.net...
> Command: _revdate
> cause this.
> Sacha T. Porter
”Boost
