While working on a file, an issue has started where if i try to select an object, or use a crossing box for selection, the program will pause, or almost stall and then continue. The stall occurs on first and second pick points of the crossing box, and any time i select in model space. The problem does not occur in papar space, but does occur if i work thru a viewport back to model space.
This is slowing my working process consdierably. The problem is something with the drawing, as other drawings will still work fine. Various other people in the company have had the same problem working on other drawings.
