AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Hatch question
3 REPLIES 3
ggunn
219 Views, 3 Replies
Hatch question
Whenever I try to hatch a region, it's solid, no matter which pattern or transparency I try to select. I start with a closed shape, pull down the hatch menu, select a pattern, click inside the shape, and it's solid and opaque, no matter what pattern or transparency I have selected.  Any ideas as to what I am doing wrong?
3 REPLIES 3
Charles_Shade
in reply to: ggunn
HPORIGIN too far from area being hatched perhaps?
I've had this happen when I try to hatch an area that the Pattern scale is to big for.
Example: I have a Hatch for 8" siding. If the area to be Hatched is only 6" in height I will get a solid Hatch of this area of the Siding Pattern.
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
ggunn
in reply to: Charles_Shade
No, that's not the issue.  If I try to hatch even huge areas, the same thing happens. Putzing around with it I can sometimes see hatch lines but they are reverse density.
pendean
in reply to: ggunn
LT version?
Which hatch menu pulldown?
Custom or stock patterns?
Did this problem just start? Or is it limited to one/few files?
Are you sure your hatch pattern size is not just real small and from a distance it appears as a solid?
Works fine here.
”Boost
