For someone unknown reason the hatch pattern preview does not work on some drawings - I have tried turning HPQUICKPREVIEW off and on but this does not make any difference. Also the hatch palette images boxes are blank at times (I have to slect the update tool image to get them back). This only happens on some drawings (others work fine). Any suggestions??
Daryl
Bad network connection to the offending machine?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
I have been experimenting further and it seems that the issue relates to other hatch patterns, blocks etc on the drawing. E.g. If I freeze some layers associated with hedgerow, kitchen, bedroom blocks etc then the hatch preview works - Any suggestions on why other blocks in drawing are causing the preview not to show?
BTW its a standalone machine
Many thanks,
Daryl
Computer and Video specs?
Maybe too much going on for the machine to handle at some point.
'Use current' is the default setting on HPLAYER and has always been this way on my computer - Anything else I could try?
Thank you,
Daryl
