AutoCAD LT Forum
Group Fail
4 REPLIES 4
germXXL
436 Views, 4 Replies
Group Fail
(Autocad LT 2014 / Win 😎
STEPS:
Group > Select Ojbects
PROBLEM:
When I go to select the objects as as a SINGLE OBJECT, each object within the group is selectable -- as if they were not grouped.
Shouldn't it be that when I select ANY of the objects within the group ALL OBJECTS in the group get  selected, and not just each object?
*****   SOLUTION:  Set PICKSTYLE to 1  *****
-gxxL
4 REPLIES 4
Charles_Shade
in reply to: germXXL
germXXL
in reply to: Charles_Shade
Thanks for the lightning fast response & solution...
...to answer your question, it was not.  It is now!
Thanks again!
-- gxxL
pendean
CTRL+SHIFT+A toggles "grouping" on and off, probably how it got turned off in the first place.
germXXL
in reply to: pendean
That's interesting, Dean.  Since I've been with the new office they only use OPENoffice Writer.  And that shortcut works in MSWord to make selected text ALL CAPS.  However, it doesn't work for Writer.
I know I fat finger my keys from time to time, but that combo seems very unlikely at this office.  It's still a possibility though....
”Boost
