I hope someone can help with this issue!
Using AutoCAD LT 2014.
Here's the sequence:
Window fades, timer wheel appears and does not rotate, widow goes blank as per attachment, no further response
If I close the window and try again it just opens up blank again!
Any help would be greatly appreciated.
Solved by pendean. Go to Solution.
Solved by Albert_Rius. Go to Solution.
Thanks for the reply.
I am signed in to 360, I presume that I have said yes to Live data as I have used Geolocation before with no problem. Is that something I can check?
The issue is that I get to certain point and it just grinds to a halt and is not responsive any more. If I close the drawing, shut down AutoCAD and try again I get to roughly the same place and it stops again, sometimes a little further. I have attached a screen shot of the situation it stops at. It is clicking on 'Drop Marker Here' that seems to be the trigger. If that does work (very rarely) and I try to move the pin then I get the blank window.
My internet connection is up, my PC's resources are fine.
If I just close the Geographic Location pop up window and try again without closing down AutoCAD it immediatley opens in the blank state.
Thanks.
If you select a differnet location, from and empty file, does it works?
If with this conditions still fails, my suggestion can be to repair your installation.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
