I am having issues trying to print a file from LT2014 in which I have overlaid my drawing on map data. The satellite image is scaled and located correctly.
The problem I am having is when I go to print the file, the satellite image shows in my viewport but when I print the file it is only my original drawing that prints without the map data.
Is it possible to print map data or am I just overlooking something?
Solved by pendean. Go to Solution.
Sometimes this can be a resources issue with windows. Have you tried restarting the computer and then trying to print. Often we get a similar problem with the image pixelated, or not printing at all. This is apparent even on Medium to High End machines with 8 GB RAM.
Scott
