I,m running Win 7 64 bit lots of ram and disk space. LT 2014 all of the latest updates and service packs. When I save a drawing by going to File, my machine freezes up and "is not responding" shows above the window. This condition lasts for up to 5 minutes before becoming a usable window again. If I use the big "A" no problem. Tools/Options/Open and Save/ and then change the number of File Open to "0" and the number of Application Menu to "0" then no problem. But then there is no memory list of drawing to go back to either under the Big A or the File. Something is broken. Please help.
Dennis
Solved by pendean. Go to Solution.
Is this a recent problem for you?
Anything change on the computer?
Any third party programs running with AutoCAD?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Dennis
My freezing problem is not solved. But now I can set the file number to 3 before it freezes at 4
I have the exact same problem. Using quick save "locks up" AutoCAD and I have to Wait.............. for everything to catch up. ITS A PAIN!!!!
