I have small problem with the tables in Autocad LT. I have to place a table in each drawing with fixed titel and header values. I knew how to get the title and header if I break the table in one drawing. But this is different story for me. I have attached an image with title and header values, I want to use the same title and header in every drawing. I don't want to create a block and explode evry time. Any help or suggestions would be very much appreciated.
Thank you,
Jnanesh
Solved by pendean. Go to Solution.
Hi, I would just keep the table in a seperate dwg and then copy/paste from that dwg rather than inserting. That way the table won't come in as a block.
Explore using ToolPalettes: it's what that feature is all about.
But whether you use that or Copy/paste or INSERT as a block (then explode), you need to ensure the TABLSTYLE and STYLE settings between all the files are identical or you'll see more issues. It helps if you don't call everything STANDARD.
