I started the drawing I have been working on for the last couple of days. I went to save it and this is what I got:
fatal error: unhandled access violation reading 0xbff247f8 exception at e47c7bd9h.
Every time I reload the program the numbers are different.
When I load a different drawing I don't have the problem.
Any ideas?
Solved by Charles_Shade. Go to Solution.
RECOVER that drawing instead of Opening it.
Any errors detected and fixed?
If you are in a newer version of LT you can get to the Recover utility under the big red A
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
I have 2013 LT and never run into this. It seems like what ever is done with that one drawing once you go to save it, it will crash the program.
RECOVER the Drawing to open it.
AUDIT, PURGE then
-PURGE as well and chose Regapps
WBLOCK the contents to a new file.
Any better?
Your Welcome.
Sometimes bad things happen to good drawings.
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
