Out of no where I started getting message: "Fatal Error unhandled e0434f4dh exception at fdab9e5dh" which then prevents AutoCAD LT 2010 to start. I have uninstalled and reinstalled twice and both times added Update 2. Any suggestions?
What changed on the computer all of a sudden?
Something triggered the change and now that you have doen the re-install route you may never find out.
Look to seee if there were any .NET updates to the system.
Did you run a Registry Cleaner perchance?
Any Norton products on your system?
Restore the computer to a week ago. If AutoCAD resets itself you are good to go.
If not:
REVO UNINSTALLER The free version on its most aggressive setting will get rid of all files.
Use this as the uninstall instead of Windows.
Then follow this advice from Autodesk:
Autodesk Recommended Clean Install Procedure:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240817&id=2887771&siteID=123112
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
