AutoCAD LT General
r.nashWHP
Message 1 of 14 (740 Views)
Accepted Solution
FATAL ERROR messages
740 Views, 13 Replies
05-16-2012 04:12 AM
Hi all,
I keep on getting the fatal error messages like FATAL ERROR: unhandled Access Violation Reading 0xffffffff Exception at 1a89fc50h, when doing simple commands such as move, copy or selecting objects. It has also occurred when I've tried to save. They can occur up to 4 times a day and as you can imagine it can get quiet annoying.
I have tried emptying my temp folders and I've ensured my copy of AutoCAD 2011 LT is up to date but these are only temporary solutions as a few days later they will appear again.
Does anyone know a why to prevent these error messages from occurring
Cheers
*Expert Elite*
Charles_Shade
Message 2 of 14 (738 Views)
Re: FATAL ERROR messages
05-16-2012 04:46 AM in reply to: r.nashWHP
Were these files created in an earlier version perhaps?
Can you post a sample problem drawing? (Post one that this has happned to.)
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
r.nashWHP
Message 3 of 14 (730 Views)
05-16-2012 05:35 AM in reply to: r.nashWHP
Yes some of the drawings where first created in an earlier version, as some of them are nearly 10 years old.
I've attached the latest drawing that I've had an error message occur whilst I've been trying to complete it. The error message that I got was on my previous post.
r.nashWHP
Message 4 of 14 (720 Views)
05-16-2012 06:54 AM in reply to: r.nashWHP
Sorry I forgot one thing, this first started to happen when I had to convert Microstation drawing (.hln files) into AutoCAD files, either as .dwg or .dxf.
Although now it the error messages appear if I'm using an AutoCAD files.
*Expert Elite*
Charles_Shade
Message 5 of 14 (694 Views)
05-17-2012 04:42 AM in reply to: r.nashWHP
I just Copied, Moved, Copy/Paste, etc. w/o issue
I wanted to see the plan in case there were excess Filters or Scale Lists. These were clean
Audit reported no errors.
The drawing is missing the XREF that is attached to it.
Have you tried detaching the XREF and making sure that it is clean as well?
*Expert Elite*
Charles_Shade
Message 6 of 14 (689 Views)
05-17-2012 06:22 AM in reply to: Charles_Shade
The drawing has been open for over an hour and no issues with Copy, Move, etc...
*Expert Elite*
pendean
Message 7 of 14 (685 Views)
05-17-2012 07:03 AM in reply to: r.nashWHP
What Windows version are you using?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
r.nashWHP
Message 8 of 14 (668 Views)
05-21-2012 12:45 AM in reply to: pendean
I've checked the x-ref and it's clean.
I've got Windows XP professional, 2002 edition.
r.nashWHP
Message 9 of 14 (666 Views)
05-21-2012 01:35 AM in reply to: Charles_Shade
I've checked teh x-ref and it's clean - I'm the only person in the office's who gets these error messages.
I've had a few error messages when I've just closed a drawing, this happened today with the one that I posted the other day.
*Expert Elite*
Charles_Shade
Message 10 of 14 (664 Views)
05-21-2012 04:46 AM in reply to: r.nashWHP
Sounds like it is time to start over.
Back up all Customizations first.
If you are allowed, grab this program REVO UNINSTALLER (Free Version) and use its most aggressive setting on the AutoCAD install. Then check thru the registry with the advice below.
Autodesk Recommended Clean Install Procedure:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240817&id=2887771&siteID=123112
You are not logged in.
Announcements
Need installation help?
Ask the Community
