AutoCAD LT Forum
Exporting my files from current version of AutoCAD LT to older versions
3 REPLIES 3
526 Views, 3 Replies
This is probably a very generic question but I need to know before I by a current version of LT. Is there a way to export files from a newer version of AutoCAD LT to an older version without to many compatabilty issues. Just so you know what I am dealing with I am trying to go from 2015 to 2004. If you can link me to the information or explain it here I would find it very helpful, thank you.
3 REPLIES 3
drjohn
DWG Trueview convert should do you OK. I think there is a batch convert in there also.
Be advised that you will lose all of the newer version intelligence (in the drawing, that is  Smiley Very Happy ) by doing so.  eg: multileaders will not convert back, dynamic blocks ... etc ... etc ...
HTH
DJ
in reply to: drjohn
thank you dr.john. Now I have done a little research on the trueviewer and there seems to problem with main download of DWG trueview, do you know of a working link for that? if not thats fine, just asking. Thank you again for the info.
drjohn
”Boost
