AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Exploding Text in LT
5 REPLIES 5
568 Views, 5 Replies
Does LT 2000/2000i have a tool to be able to explode regular text (not
mtext). ACAD 2000 has the express tools that accomplish this and I was
wondering if LT did too, or if anyone knows about a plug in for it.
Thanks.
5 REPLIES 5
No such tool in LT, and no such plug-in.
You can however do it the long way: set up an HPGL plotter
(PLOTTERMANAGER>HP>7475), plot the text to file. Then get one of the free
HPGL2DXF programs out there and bring it back in:
http://www.guthcad.com.au/free_cad.htm
Dean Saadallah
www.pendean.com
"Ryder Audette" wrote in message
news:3B15001D.330AA4F5@netzero.net...
> Thanks.
Try this trick:
Save the text as WMF, type WMFOUT at the command line.
Then simply bring it back with WMFIN.
Now the text can be exploded into single letters.
And thats not enough, you can explode the letters as well.
Works only on shx text, not true type text :o(
Conny
> Thanks.
On Wed, 30 May 2001 07:13:49 -0700, Ryder Audette
Do a WMFOUT of the text, then a WMFIN of the file created. Explode
the WMF block and rescale it.
Ian A. White, CPEng
WAI Engineering
Sydney 2000
Australia
Ph: +61 418 203 229
Fax: +61 2 9622 0450
Home Page: www.wai.com.au
On Wed, 30 May 2001 14:45:59 -0700, Conny Klasson
wrote:
>Try this trick:
It should work on TTFs as well. I have done it many times. It is
very useful when developing logos etc. for title blocks.
Ian A. White, CPEng
WAI Engineering
Sydney 2000
Australia
Ph: +61 418 203 229
Conny Klasson wrote in <3B156A16.F6C00D3F@bigfoot.com>:
>Try this trick:
It will work with TT if the width is other than exactly 1. It can be
1.00001 or 0.999999, just not 1.
Enjoy,
Stef
mailto: yodersj@ipass.net || Drafter, Leather-worker
http://www.ipass.net/~yodersj/ || Dos, Win, LT
in progress http://computerhowto.homestead.com/
RFC 1855, section 3.1.1, item 10 at http://www.faqs.org/rfcs/
”Boost
