We recently added one license of LT 2014, and the Explode command works differently than before with dimensions.
Using the standard filled arrowhead, the arrows now explode into unfilled triangles. In past versions it's always exploded into the filled arrowhead, just like it was when created.
Can't find any option to alter the way Explode works. Anyone know the answer?
Solved by pendean. Go to Solution.
Checked again - it's only when attempting in older drawings. When a new drawing is made, it explodes as it used to. Anything from LT2007 and before though (and possibly later, but we don't have any between 2007 & 2014).
Also attempted to save a newly created drawing as an LT 2007 .DWG, but it exploded just fine.
Any help is appreciated.
