I'm trying to use this to knock a drawing back so the engineer can see the Multileaders.
He's on LT 2000 and communication of the drawing file can be problematic.
If I've read the (of little)Help file correctly I should be able to enter 2000 in the Format selection and have a 2000 file.
This is returning Invalid option keyword when I try.
What is the proper Format?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Solved by zalant. Go to Solution.
This has been escalated by Autodesk. If the outcome does not post here I'll be sure to pass on the info.
I can confirm that this issue is reproducible in the 2013 version of AutoCAD LT, even with the service pack installed. If you do not choose the format option, it appears to go ahead and create a 2013 version of the DWG (with AEC content stripped out). Once you have that file in hand, use the DWGCONVERT command to change it to the 2000 (or any other) DWG format.
So an extra step needs to be put into the code.
I can use that workaround.
Thanks for the follow up.
