I haven't reviewed the recommended posts, but just a quick question. I am in the 'Dynamic Block Editor' command. I am trying to add a stretch application to the block (a simple section flag), and I have success up until the point where I save and go back into the drawing. There I do not get a pull-down tab and it will not allow me to stretch where I have defined the block through the 'Parameters' and 'Actions' tabs. Help!!
Always post your Dymanic Block for help. It is easier to see than explain.
Dynamic Actions are controlled by Grips that are assocaited with Dynamic Properties.
Unless you have added a Vis State or a Block Properties Table. These two items have drop downs that you can choose from.
Dynamic Block Forum link is in my signature.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
