Show only
Search instead for
My last question worked so well I thought I would venture forth with another "I'm accoustomed to" statement.
I'm accoustomed to using a utility which loads tabs for each open drawing. This allows clicking on the tab to switch between drawings rather than using "window" and searching for the drawing I desire to work in next. I have been given a utility (not the one I used in Building systems at my former employer's place) which works fine except I can't get it to re-load automatically each time I open AcadLT. The utility is "iDwgTab2007" and has an option to reload on startup but it doesn't happen for me. I use LT 2009 on a Vista system. I think the utility is Korean in origin and I don't have documentation. Maybe someone has another utility which works in a similar manner or has already found a solution for this utility?
Since R2005/LT2005, TASKBAR command has been a core feature. Explained in
HELP, sounds like you might benefit from 30minutes worth of browsing through
the commands and variables list in HELP (AutoCAD or LT):
HELP>Contents Tab>Command Reference chapter>Commands for sure and possibly
Variables if you still have time.
