I have a raster image (aerial photograph) linked to an XREF in my base drawing. When I display the image which is on its own layer in comes up in front of everything else. How do I select the image and "send to back" in draw order command? I do not know how to select the image. I even tried using Qselect.
Solved by sthompson1021. Go to Solution.
I believe you have to select the entire xref to use the send to back command unless you bind the xref.
Thank you sir. I wish you could choose Xref by name from a drop down list rather than typing the name, but it worked.
