For some reason my dimensions are not showing up in the layout in paper space. They are in a seperate layer called "DIM".
Any hints?
Thanks.
Solved by edwin.prakoso. Go to Solution.
Are all dimensions are not showing? Are they disappear on all viewports?
Check the layer properties when you open the viewport with missing dimensions. It might be the layer properties is overriden for that specific viewport.
And also check with annotation scaling. It's possible that the dimensions are not showing because the annotation scale is different with viewport scale.
