AutoCAD LT Forum
Dimension Text
5 REPLIES 5
david.hobson
1295 Views, 5 Replies
Dimension Text
When copying dimensions within a drawing, the figure and/or text is shown bold and I cannot change it. A similar problem occurred with ordinary text and was solved using the "Z" properties. The same principle does not apply to dimensions. Is there a cure for this problem?
5 REPLIES 5
Do you have the Text Style you are expecting assigned to the Dimension Style that you are using?
pendean
in reply to: david.hobson
Post a sample DWG with the problem or browse around here for a macro you can add to LT using CUI command: Z=something other than zero remains the problem, but PROPERTIES command does not offer a fix for dimensions if that's what you mean by "not working".
Charles_Shade
in reply to: pendean
-Flatten Z coordinate:
^C^C_move;_all;;0,0,0;0,0,1e99;_move;_p;;0,0,0;0,0,-1e99;
That should be in the FAQ Smiley Wink
david.hobson
Good morning.
I'm not sure if I am doing this correctly but I have tried to attach a drawing highlighting my problem with dimension text showing bold which I am trying to eliminate.
I think it is something to do with "Z" coordinates but I cannot resolvemy issue.
Your help would be greatly appreciated.
regards
DAveid Hobson
pendean
Setting UNITS to it's highest precision settings shows the problem in PROPERTIES command and LIST command for text and dimensions (see attached).
You'll need to use the macro posted above to fix the dimension strings. Here is a tutorial on how to add it to a button or panel using CUI command if you need it:
http://cad-notes.com/2012/02/exploring-autocad-cui-creating-a-command-part-2/
http://www.augi.com/library/understanding-the-customize-user-interface-cui
”Boost
