AutoCAD LT Forum
Dimension Styles
1 REPLY 1
patrick.arnold
176 Views, 1 Reply
Dimension Styles
I rarely use dimensions as I mostly draw circuit diagrams. When I do, I have to modify the standard style for the scale etc. Is there some way of having a library of dimension styles to import into a drawing as there is with linetypes? I use LT2005.
1 REPLY 1
hwalker
in reply to: patrick.arnold
Create a master drawing and make new dimension styles in that. Then add it to your favourites and you can import into your current drawing the dimension style that you want using Design Center
Howard Walker
Left Handed and Proud
”Boost
