PLOT settings are saved per file per layout.
To always plot using your devices, you will need to customize and create
some basic macros using -PLOT command (note the dash). You will have to
create one for each device and each paper size for each device, and you have
to decide up front if you want to plot the default (window, view, limits,
layout) etc.
The following is a very basic macro to just plot, simply change the device
name (put your plotter/printer name where shown):
^C^C-PLOT;;;PLOTTER_NAME_HERE;n;n;y;
You can also explore using PUBLISH to output to DWF first, then print the
DWF later.
Or INSERT or XREF these other files into already defined templates of yours
then simply PLOT.
Dean Saadallah
http://LTisACAD.blogspot.com
