AutoCAD LT General
Active Contributor
Message 1 of 8 (311 Views)
Accepted Solution
DWG to PDF - Part 2
311 Views, 7 Replies
05-03-2012 08:25 AM
I am using AC LT 2008.
I have a drawing that measures 34 x 19 and I must print it at  a scale of 1:1.
In Plot - Model I use Printer Name - Dwg to PDF, Paper Size - Arch D 36 x 24,
What to Plot - Extents and Scale - 1:1.
I review this in Preview and it looks fine so I then complete the Plot
The PDF file is saved on my Desktop and when I open it it looks fine.
I then Upload the file to Staples Copy Service. Their paper size choice is 24 x 36.
When I preview it at Staples the drawing is cropped because of the orientation of the paper
They do not seem to have a paper size of 36 x 24 or any Rotate feature...
Now I go back to my drawing and rotate it 90 degrees.
In Plot I again use Printer Name DWG to PDF, I change the Paper Size to Arch D 24 x 36, Extents and 1:1.
When I preview this from the Plot screen the 'paper'  the image is on has a landscape orientation and much of the image is cropped.
What am I misunderstanding or doing wrong here?
Thanks for your help.
As a bonus question What is the difference between a paper size of Arch D and Arch D Expand?
*Expert Elite*
Charles_Shade
Message 2 of 8 (308 Views)
Re: DWG to PDF - Part 2
05-03-2012 08:51 AM in reply to: trvlnmny
Arch D takes the Margin into consideration and Arch D Expand does not (at least that is what I believe).
Do not rotate your Drawing.
Set your paper to 24 x 36 and change the Orientation to Landscape (or Portrait).
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
Active Contributor
Message 3 of 8 (306 Views)
05-03-2012 09:00 AM in reply to: Charles_Shade
I do not see where to set the orientation to Landscape or Portrait.
*Expert Elite*
Charles_Shade
Message 4 of 8 (300 Views)
05-03-2012 09:16 AM in reply to: trvlnmny
From the right side of the Publish dialog
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
Active Contributor
Message 5 of 8 (298 Views)
05-03-2012 09:27 AM in reply to: Charles_Shade
Never saw that panel before.
Found it now that I know it is there.
Thanks for the help.
*Expert Elite*
Charles_Shade
Message 6 of 8 (295 Views)
05-03-2012 09:31 AM in reply to: trvlnmny
That arrow down at the bottom of the dialog gets many a person.
Expanded view like this should probably be the default view of this dialog.
Active Contributor
Message 7 of 8 (292 Views)
05-03-2012 09:33 AM in reply to: Charles_Shade
Is it possible to set AC so that panel always shows?
*Expert Elite*
pendean
Message 8 of 8 (288 Views)
05-03-2012 10:11 AM in reply to: trvlnmny
It shoudl always stay open until someone minimizes it: if it does not stay open, your Windows Profile may be limiting your access to the Windows Registry where that is saved I believe (or you could just have a corupt Windows Registry entry).
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
