AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
DIMALIGNED
2 REPLIES 2
kthr331
388 Views, 2 Replies
DIMALIGNED
AutoCAD 2013 LT. I would like see if my USC is set to world so I can DIMALIGNED. The instructions say to go " Ribbon:  View tab,  Coordinates panel,  UCS". I can find the Ribbon and the View tab, but I do not seem to have what it takes to find the Coordinate panel. All ideas, suggestions, comments about where I may find the Coordinate panel will be greatly appreciated. Thanks, K.
2 REPLIES 2
pendean
in reply to: kthr331
You probably have it turned off: right-click at the far right end where the ribbon runs out and select it to turn on. Remember to save your workspace with WSSAVE command or it will go away at some point in the future.
OR... At the commandline, type UCS, then tap the <enter> key on the keyboard, then type W and <enter> again.
kthr331
in reply to: pendean
Thanks pendean. It worked fine. Appreciate the help. K.
”Boost
