AutoCAD LT Forum
Creating transparent solid hatch?
3 REPLIES 3
mdarmstrong
335 Views, 3 Replies
I'd like to hatch a large area a solid color while still allowing the black lines within that area to read through the color. Whenever I plot, the solid hatch completely covers all of the black lines. Is there a setting that allows this transparency that I am missing?
MDA
3 REPLIES 3
in reply to: mdarmstrong
Hatch patterns can't be transparent. Can you use
DRAWORDER to send the hatch pattern to the back, so the objects behind are
displayed and printed in front?
David Byrnes/Vancouver BC
Assistant
Moderator - AutoDesk Discussion Forums
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I'd
MDA
mdarmstrong
Thanks Dave. That works. It does require a lot of object selection to place things in front or behind but it does print correctly.
I found that you can also place the hatch pattern in paperspace and un-check the print paperspace last button. That method is even more complicated though.
Thanks again.
Mike
Having layers, and putting items like Hatches on their own layer would
simplify the selection method and make DRAWORDER easier to work through.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
”Boost
