AutoCAD LT Forum
Create a drawing title block
4 REPLIES 4
373 Views, 4 Replies
Hi
I'm working with a drawsheet title block which was created before I came to this business.
I need to add additional data to the title block.
The title block has been created as a block, I open the block in block editor to add detail like another issue level area in the title block.
How do I add in the data for the title block prompts without having to copy, paste and modify a previous line?
If I do add the extra detail in by copy, paste & modify the finished text does not display how I want it to and when I come to sync the block changes the new text shows as red rather than black.
Confused!
Cheers
Jon
4 REPLIES 4
AcadAdamLT
If you can post the block it would be easier for us to support you.
Signature, sincerely... //Adam
AutoCad LT 2016
Give Kudos where credit is due, Mark "accepted as solution" if the post solved your question.
See attached.
pendean
Are you just looking for a tutorial on how to add attributes? copy/paste is not the best way to do so.
Here are some ideas:
http://www.ellenfinkelstein.com/acadblog/tutorial-create-attributes/
http://www.youtube.com/watch?v=fRTRxsjap8Q
http://www.youtube.com/watch?v=q187yT9Brfw
in reply to: pendean
Yes I am, thank you for the links I'll check them out and try again.
Cheers,
Jon
”Boost
