Yesterday I went to open AutoCAD LT 2012 and after the splash screen froze, was greeted with the "AutoCAD LT Error Report" window. With increasing thoroughness I first "repaired", then "reinstalled" then removed and reinstalled, then removed using the Autodesk instructions for removal and reinstalled, then reinstalled c++ 10 runtime, then reinstalled DirectX, then uninstalled with manual edits to references in the registry and reinstalled, then used the psebuninstalltool.exe utility to uninstall and reinstalled (from DVD).
Same result each time: Splash screen, "First Run Initialization", then "AutoCAD LT Error Report" window.
I would like to access my drawings.
Please advise -
Solved by pendean. Go to Solution.
Windows System Restore should always be your first "fix" when software suddenly stops working: try it, it may still help.
Used Windows Restore to point before last Critical Windows Update. Problem Solved. Wished I had tried that first!
-- Thanks!
Do you allow Windows to update on its own?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Yes. Windows 7, 32 bit. Would it be better to install the updates manually?
Or mosttimes not at all.
.NET updates can be real buggers. I've not noticed C+ so much but if you do these manually you at least know which mucked with what when something happens.
I made the mistake of updating the Mouse and Keyboard the other day. Never again.
