Not for LT2000 or earlier: what you need is to either get the sender to
Explode the custom entities first and then send you the file.
If you have LT2000i, you can download and install the Arch 2.51i OE enabler
(make sure you install the correct version noted):
http://www3.autodesk.com/adsk/section/0,,331753,00.html
These enablers let you see the objects as the original software does, and
manipulate them as you need.
Dean Saadallah
www.pendean.com
"Tim Clare" wrote in message
news:2EA619808586DB56AA3AFE270A5328DE@in.WebX.maYIadrTaRb...
> I have received a drwg from a client which was done in Architectual
Desktop
> Release2. When I open the drawing all the doors etc just appear as square
> blocks, does anybody know if there is a 3D to 2D converter to purchase or
> download so I can eradicate this problem.
> Please help, its very perplexing.
