AutoCAD LT General
mdwyerva
Message 11 of 12 (201 Views)
Re: Cleaning Up files using DXF + Recover
02-01-2013 10:06 AM in reply to: Charles_Shade
The circle file is 3MB because of all the linestyles and textstyles that it mysteriously (to me) drags along with it.  These are all from the underlying architectural xrefs (which were not selected!).   It is pretty bizarre, since if you do a LIST ALL on this 3 MB file, you get exactly one object.
Command: list
Select objects: all
1 found
Select objects:
CIRCLE Layer: "de-mducts"
Space: Model space
Handle = a8
center point, X=950'-8 27/32" Y=54'-9 17/32" Z= 0'-0"
radius 0'-3"
circumference 1'-6 27/32"
area 28.27 sq in (0.1963 sq ft)
The only way I found what was in it was to do a PURGE and look at items that can not be purged (there were NO items that could be purged).
Not sure why wblock ENTIRE would perfectly clean a big pig drawing, and why wblock SELECT would include a 10 ton pile of crap in with a simple object.
mdwyerva
Message 12 of 12 (169 Views)
02-06-2013 07:56 AM in reply to: mdwyerva
and for any lurkers... I find that people need to be set to save in 2010 dwg format to see max reduction.
You are not logged in.
Announcements
Need installation help?
Ask the Community
