AutoCAD LT Forum
Changing Shape of a Viewport
11 REPLIES 11
Message 1 of 12
John Colgan
6668 Views, 11 Replies
Is it possible to create a new view port with 5 or more grips, or modify an existing rectangle. i have search everywhere but still no joy.
11 REPLIES 11
Message 2 of 12
in reply to: John Colgan
You can modify polygonal viewports with LT but you can not create them. Use
the attached template to copy/paste the shape you want.
Chip Harper
Autodesk Discussion Group Facilitator
http://home.comcast.net/~hot4cad/
Message 3 of 12
Charles_Shade
A very nice gift.
Thank You,
Charles Shade
Message 4 of 12
Your Welcome 🙂
Chip Harper
Message 5 of 12
Faza
tq for the attachment.
But how to make these polygonal viewport by using LT?
Message 6 of 12
Charles_Shade
Read Chip Harper's reply
LT cannot create polygon viewports, only manipulate them. Hence the need to cut and paste.
regards,
cshade
Message 7 of 12
Faza
There must be a way to make these polygonal viewports probably from other AutoCAD software? I guess. Do you know how I can get this information? Can AutoCAD 2005 or 2006 Full version can do it? If can How to do it?
Thanks & regards.
Message 8 of 12
Charles_Shade
The viewports were made using full autocad I do believe. That is the point of the gift above since LT won't.
Try searching the 2006 or 2005 discussion group, not the LT group and you should find your answer. LT will not create these viewports. Search this sight to see if there is an add-on but I don't beleive there is.
regards,
cshade
Message 9 of 12
tapan19900
HII I M A NEWBIE IN AUTOCAD BUT HAVE A HOBBY TO SEARCH EVERY THING
I THINK I HAVE YOUR ANSWER...
GO TO TO VIEW TAB IN THE TOOL BAR....THERE U FIND A VIEW PORT LINK WITH SIDE ROLL MENU.....IN THERE U WILL BE SEEING A LINK NAMED POLYGONAL VIEPORT.......
THIS HOW U CAN CREATE ANY SHAPE OF VIEW PORT U NEED
Message 10 of 12
pendean
in reply to: tapan19900
You've latched on to a very old thread that for the most part has been cured in LT since the year 2006.
Message 11 of 12
Charles_Shade
in reply to: pendean
An example of a workaround thread that should be updated  to only older versions of the software perhaps?
Message 12 of 12
pendean
in reply to: Charles_Shade
Old threads need to be better tagged as 'old': I'm sure our friend missed it was a 2006 query that is not a current issue.
”Boost
