AutoCAD LT General
Active Contributor
FLHX
Message 1 of 5 (168 Views)
Changing Layers with "Downloaded" Drawings
168 Views, 4 Replies
11-20-2012 12:55 PM
I posted earlier about problems with drawings that I download from commercial vendors, (Grainger, McMaster, etc).  I figured out how to get access to them:  When I convert them from .DXF to .DWG. it somehow allows me to correctly dimension them.
One more problem I have with these drawings is that although I can edit them, one of the most important things I need to be able to do is change the layer they're on.  I can't figure out how.  I usually use the "Change to Current Layer", LAYCUR, command, but it doesn't seem to work for these commecially downloaded drawings.
They're always in "Layer 0". I've created multiple other layers that I need them in, but I can't get them to move.  When I select them and then click on the Change to Current Layer button, they just don't move.  'm drrawing in Model Space.
Anyway, this forum ALWAYS seems to provide helpful information.
Thanks!
Charles_Shade
Message 2 of 5 (165 Views)
Re: Changing Layers with "Downloaded" Drawings
11-20-2012 01:44 PM in reply to: FLHX
Post one please.
And Layer 0 is not Locked by chance is it?
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
pendean
Message 3 of 5 (157 Views)
11-20-2012 02:04 PM in reply to: FLHX
Are you turning off or freezing layer 0? You should never do that in AutoCAD. Ever. Leave it on, unlocked, thawed, visible and never-ever draw anything on it you need to turn off or lock.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Active Contributor
FLHX
Message 4 of 5 (141 Views)
11-21-2012 03:55 AM in reply to: FLHX
Here's one that I'm referring to.
pendean
Message 5 of 5 (135 Views)
11-21-2012 05:12 AM in reply to: FLHX
Seems to change to any layer I create and move the objects to: re-reread my last post, I think you are doing more that you are admitting in the top file.
Or are you not aware that you also need to change the object's color, linetype etc. as well?
You are not logged in.
Ask the Community
